The garage
What grease shall I use for squealing Starter Motor?
Topic: What grease shall I use for squealing Starter Motor? (Read 1696 times)
GAZ666
28 March 2012, 21:32 »
Gonna attempt to rip the starter out soon, and just wondered what grease to use? My dads got all sorts, so wanna make sure I use the right stuff...
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: What grease shall I use for squealing Starter Motor?
29 March 2012, 17:42 »
I would use lithium moly or something similar, to be honnest multi purpous would probably be ok. I would be happy with M/purpous On the internal plantary gears.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Dannyavw
29 March 2012, 18:41 »
If its a dsg theres stuff called life oil and you spray this grease on the flywheel ring gear and the end of the starter let me know and I can get the part number from work tommorow
GAZ666
29 March 2012, 18:48 »
Its a 1999 1.8t, not dsg
stfc_gti
30 March 2012, 09:04 »
ky....wait....wrong thread
2002 1.8T GTI AUM, Standard (not for much longer)
The garage
