Author Topic: n75 boost troubles ??  (Read 727 times)
Offline nolandubholmes
« on: 28 March 2012, 20:08 »
had a few troubles with spikeing boost and boost levels dropping off got a new n75 off wazzzer big thanks for that cheap as chips  :smiley: it is loads better but is now spiking at 21psi and holding 14 psi in 2nd then spiking 22psi holding around 18psi in all other gears but every so often it surges to 22psi then drops back to 14 psi no were near as bad as it used to be before i fitted this new n75 but still does it to a point any ideas im starting to think the map is possibly a bit sh!t as ive no history of who did it nor a recipt from the previous owner i think a stage 2 map is on the cards next week anyone reccomend anyone in the lancashire area ????
aum no spec as no matter what i do il never be happy
Offline wolfie1981
Re: n75 boost troubles ??
« Reply #1 on: 28 March 2012, 20:24 »
im looking a n75 if anyone has a fully working one for sale to fit agu 99 model
i dont think im hitting boost as i should
