Author Topic: Few questions about my golf  (Read 1936 times)
Offline mike1990
« on: 28 March 2012, 17:26 »
Hello,
I took the passenger side lock blank out today, because the outside door handle wouldn't open the car so i put the lock wire thing back in and it works now. Now the round metal piece that holds the lock in place has fell down the door. Is this a door card and plate removal job?
My instantaneous mpg display goes wild, it shows mpg that i know isn't possible in the golf, like 110mpg? i wish lol why does it do this?
Also, my boot lock won't open. It's stuck in the verticle position, which i believe to be the position that the remote central locking would open it. The boot handle won't open the boot, the lock won't turn with the key in. How would i get into the boot, i've heard i'll have to take the boot card off from inside but i don't want to damage anything. Any ideas on getting the card off from inside the boot would be appreciated.
My car is a 1.8t AUM 51 plate golf gti
Thank you
Offline richw911
Re: Few questions about my golf
« Reply #1 on: 28 March 2012, 17:45 »
1 Yes door card off.
2 It may be on actual MPG press the button on the end of the stalk to scroll through to avarage mpg (circle with a line symbol)
3 Try somthing like WD40 in the lock barrel it should free up and unlock, Give it time to soak in.
Offline dom
  • Back in a Mk4
« Reply #2 on: 28 March 2012, 17:47 »
Hello,
Thank you
1. Whip the door card off - simple job.
2. You've answered your own question, it's instant mpg, not average.
3. WD40 :wink:
Offline dom
  • Back in a Mk4
« Reply #3 on: 28 March 2012, 17:47 »
Damn you Rich, I was too slow :angry:
Offline mike1990
« Reply #4 on: 28 March 2012, 18:54 »
I'll have a look thank you :)
Offline mike1990
« Reply #5 on: 29 March 2012, 11:36 »
I've sprayed wd40 in the lock but it just won't turn. When i press the unlock button when the car is locked, i can see the boot lock barrel trying to turn. Any ideas?
Thank you
Offline johnomk4
« Reply #6 on: 29 March 2012, 11:48 »
Dose your rear washer work?
Offline mike1990
« Reply #7 on: 29 March 2012, 12:05 »
No, it doesn't work
Offline johnomk4
« Reply #8 on: 29 March 2012, 12:10 »
The pipe has come off then and soaked your lock. I think you will have to get into the boot and try to get the pannel of to get at it.  :smiley:
Offline mike1990
« Reply #9 on: 29 March 2012, 12:16 »
I thought that's what would of happened, is there a method of taking the trim off from inside the boot? was thinking of getting a large long screwdriver down the top near the window and pushing it down then pushing the screwdriver down, to prise it off. I don't know the best way to get it off
