Author Topic: Driver's window. Banging my head against a wall.  (Read 1249 times)
Offline craig180
Please someone give me a really simple answer to my problem.
Since buying my mk3 GTi the front drivers window hasn't worked. I've dismantled the door card and checked what I can. The switch works as I can hear a click inside the door but there is nothing! Is it/could it be as simple as a knackered motor or is there anything else I should be checking for???
Offline tweed
Re: Driver's window. Banging my head against a wall.
« Reply #1 on: 28 March 2012, 15:30 »
Sounds like the mech to me mate. Snapped wire or pulley. Motor Will be fine.
Offline javalin
« Reply #2 on: 29 March 2012, 16:29 »
could be the wiring between the door and the car.  Common cause of failures is broken or breaking wire in the bellows.
Lots of stuff on my blog from last summer relates.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline craig180
« Reply #3 on: 29 March 2012, 19:05 »
Cheers guys.
Did look through your blog javalin.
It's weird. It's getting power as I can hear the solenoid in the motor clicking but doing nothing else
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 29 March 2012, 20:46 »
Deffo  need a new regulator mate,remove the motor, plug it back in then try the switch  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 30 March 2012, 00:42 »
or the motor is jammed. Just tap it with a hammer (just like a starter motor) happened to me a few years back. Hit it with a hammer and get someone to keep pressing the button down. And eventualy it will free. Or you can replace the motor shouldnt cost more then 20.
*****MK3 Anniversary*****
*****MK4 GTI T*****
