Golf mk4
Wazzzer
brake pad check
Topic: brake pad check (Read 1776 times)
akz786
brake pad check
30 May 2005, 00:12 »
anyone get this with new pads? been told the sensors are not in, where are these located and which pads do they come with.
a yellow warning light stays on and i get brake pad check on the comp screen at ignition startup
Sugar79
Guest
Re: brake pad check
31 May 2005, 09:05 »
if i remember correctly the sensor is on the passenger side its just a cable on the end of one of the pads that plugs in to a other clip, did you get the brake pads with the sensor???
topher
Administrator
Serious forum addict
fully functioning
Re: brake pad check
31 May 2005, 11:10 »
you have to get the pads from vw .. ive not seen aftermarket ones with the sensors in
Sugar79
Guest
Re: brake pad check
31 May 2005, 11:31 »
I bought mine from that horrid place Halfrauds (lack of cash lol) think they were about £30
Came with the sensor, and they stop the car perfectly.
akz786
Re: brake pad check
31 May 2005, 23:09 »
thanks guys i bought the car like this, i just wasent sure, il buy some with the sensors the light is just annoying thats all.
boxxer1973
GTI forum regular
Re: brake pad check
05 June 2005, 13:52 »
if your old pads had them just cut and join both wires together and put on the sensor and this will work no more yellow light
Golf mk4
Wazzzer
brake pad check
