Author Topic: hope it aint a bomb!!  (Read 1685 times)
Offline jase555
  • DUBS DONT DIE, THEY JUST GET LOWER!!
« on: 29 May 2005, 22:38 »
can any help?? my Mk2 gti 8v has a ticking noise coming from the clocks and the faster i go the faster and noisier the ticking. can it be cured or is it a replacement??
some instruction would help too
Cheers guys
Offline the_GTI_new_guy
Re: hope it aint a bomb!!
« Reply #1 on: 30 May 2005, 11:52 »
Must be the cable on the back of the rev counter. Something must have worn or came off. Pain in the ass job though.
Offline jase555
« Reply #2 on: 30 May 2005, 12:09 »
can anyone run through what i need to do to sort it???
Offline Mr Blue
« Reply #3 on: 30 May 2005, 12:48 »
take all the switches out by pulling them out carefully. sterio out and pull the heater switches and heater control surround out.
unscrew all the screws you can see. there are about 6 i think and 2 above the clocks.
now the dash surround should come out.
To take the clocks out just unscrew the two screws holding them in place.
tricky bit is to get your hand behind the clocks and clip the speedo cable back in place. if its worn then replace it
thats about it really :undecided:
now clean the stuff while your at it and refit :wink:
« Last Edit: 30 May 2005, 12:50 by Blue Mk2 »
kingsmk2
« Reply #4 on: 30 May 2005, 14:26 »
tbh when i had this on my old mk2 it was because id pushed the reset tab in on the trip counter and it hadnt engaged properly!! when i pushed it again firmly it cured the noise..
Just a thought
Offline jase555
« Reply #5 on: 30 May 2005, 22:09 »
cool thank guys. i will try those things
 :smiley:
Offline BobbyT
« Reply #6 on: 03 June 2005, 09:37 »
mine do the same, i just turn the radio up!  :rolleyes:
getting some white dials soon so will see if i can cure the problem then!  :smiley:
Offline animaniac
« Reply #7 on: 05 June 2005, 04:13 »
cheap speedo cables do that......makes the clock tick!!!
it was a regular tick machine morning day night afternoon..... tick tick tick tick tick tick tick tick tick......
how many ticks is that........alot!! :grin:
that clocks ticked 1 to many times
 :grin: :grin:
try a new speedo cable.....
