Author Topic: Creaking when turning at low speeds *video included*  (Read 1798 times)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Get a creaking noise when turning at low speeds (5mph or under) and stationary.
What could this be?  :huh:
http://img841.imageshack.us/img841/9400/nk3.mp4
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Creaking when turning at low speeds *video included*
« Reply #1 on: 16 August 2012, 11:36 »
Anyone??  :undecided:
Offline dom
  • Back in a Mk4
« Reply #2 on: 16 August 2012, 11:42 »
Just sounds like springs creaking to me, what suspension you running?
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #3 on: 16 August 2012, 11:46 »
Running coilovers.
Was creaking when turning left when I had old OEM suspension on too, but recently does it when turning right too.
Top mounts?
Offline jamie1989
« Reply #4 on: 16 August 2012, 11:48 »
I was thinkin top mounts mate.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #5 on: 16 August 2012, 11:50 »
Don't think they were replaced when coilies were put on about 2 years ago.
Would it be much of a ball ache to replace them now just at the front?
Offline dom
  • Back in a Mk4
« Reply #6 on: 16 August 2012, 12:00 »
Piece of piss if your running coilovers, jack car up, wheels off, undo 19mm top nut. The hub/coilover should drop down giving you enough access to replace the top mount while it's still on the car :wink:
Offline jamie1989
« Reply #7 on: 16 August 2012, 12:01 »
Piece of piss. Undo the bolt through the hub and strut, undo the drop link and top nut holding the strut in the engine bay.
Remove the strut, the top mount sits on top of the strut and the bearing is bolted to it.
Takes about an hour to change both sides really.
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #8 on: 16 August 2012, 12:03 »
Okay thanks guys, how much for top mounts roughly?
Offline jamie1989
« Reply #9 on: 16 August 2012, 12:03 »
The strut will have to be removed buddy as the bearing is bolted down.
If your changing just the mount then do exactly what Domo69 have said takes 20mins max. (check the bearing if its nice and free then just replace the mounts)
