Author Topic: Passenger door handle won't open door from outside  (Read 2036 times)
Offline mike1990
Hello, the passenger outside door handle wont open the door from the outside, it happened after i closed the door this morning. Ever since it wont open, is this a easy fix?
Thank you
Offline johnomk4
Re: Passenger door handle won't open door from outside
« Reply #1 on: 25 March 2012, 16:58 »
Will it open from the inside?
Offline mike1990
« Reply #2 on: 25 March 2012, 17:00 »
Yes, will open from the inside
Offline navmk4gti
« Reply #3 on: 25 March 2012, 17:02 »
happened to my rear passenger door too.. then after month started working again itself been fine since :grin:.. i think its just on periods  :lipsrsealed:
Offline mike1990
« Reply #4 on: 25 March 2012, 17:15 »
Hope it sorts itself out lol or i might just take the door card off and see what's stopping it opening
Offline johnomk4
« Reply #5 on: 25 March 2012, 17:19 »
It could be the little pull rope has come off, but my o/s rear door sticks every now and then. It might free off. Like you said take the door card off, or even take the lock out and see if that little rope is still attached.  :smiley:
Offline mike1990
« Reply #6 on: 25 March 2012, 17:21 »
Yes, i'll have a look and let people know. I didn't even slam the door shut it was just a normal push lol
Offline navmk4gti
« Reply #7 on: 25 March 2012, 17:22 »
I think the module was just sticky.. been ok since tho was bit stiff first but becuase been opening closing door few times it is normal now and has been for about a year  :smiley:.. if you do open it up check module is not jammed just pull latch on it up and down to see if it is engaging.. and check the cable to the door handle from module..there a right fookin pain to change btw  :lipsrsealed:
Offline rio_gti
« Reply #8 on: 25 March 2012, 23:27 »
Easiest and first step I would suggest too, taking the lock out and checking the "little rope" will take 5 mins
