Author Topic: Clutch pedal change  (Read 882 times)
Offline Gavo1989
Clutch pedal change
« on: 24 March 2012, 18:46 »
Has anyone changed thier clutch pedal? I had the dreaded clip snap and my pedal snapped so me and my dad are going to change it. Only problem is the spring in the pedal. Has anyone done it them selfes without using the proper tool to remove the spring? If so what did you use.
Thanks
Gavin
Offline JC
  • Back in the North.
Re: Clutch pedal change
« Reply #1 on: 24 March 2012, 18:47 »
1, What mk of golf ?
2, then use the relevant section as getting helped out on fixing a mk2 might not be much use if yours is a mk4
 :smiley:
Offline Gavo1989
« Reply #2 on: 24 March 2012, 19:07 »
sorry mk4 and i thought it would be arlight here. My bad
Cant is be moved?
« Last Edit: 24 March 2012, 19:13 by Gavo1989 »
Offline mcgee9t2
« Reply #3 on: 24 March 2012, 20:06 »
yep im shure one of tyhe mods will move in a min.
mine went a year or two ago.
however i paaid my cusn to do it cause i was told its a right arse on. so no help :grin:. but hope you get it sorted
