Golf mk4
Wazzzer
lowering spring caps do they work??
Topic: lowering spring caps do they work?? (Read 1246 times)
rench
Here all the time
23 March 2012, 23:04 »
got a mk4 anni and want to lower it some more on the front, be told they lowered 30mm and found these on ebay that will drop it an extra 10mm, so it would be 40mm which is as low as i can go without changing arb. any one used these are they ok? not bad money.
http://www.ebay.co.uk/itm/FK-10mm-Lowering-Springs-Caps-VW-Golf-Mk4-Mark-4-/330622768932?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item4cfaa71724
http://www.golfgtiforum.co.uk/index.php?topic=228442.0
nolandubholmes
GTI forum regular
Re: lowering spring caps do they work??
24 March 2012, 12:22 »
yeh they work but only on a standard style shocker and not a coilover its all to do with how there made basically 10mm shorter than the standard coil spring holder
aum no spec as no matter what i do il never be happy
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
24 March 2012, 12:38 »
Yep they definitely do what it says on the tin mate
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
houston
24 March 2012, 14:55 »
polo top mounts work too, but i think these take you down about 20mm. but personally id prefer to stick with oe for stuff like this
rench
Here all the time
24 March 2012, 17:32 »
My Annie's supposobly lowered 30mm anyway so thought these would be alot cheaper than buyIng coilovers just for an extra 10mm lower.
Golf mk4
Wazzzer
