Author Topic: help on clutch adjustment please  (Read 5574 times)
Offline ashmk1
« on: 20 April 2003, 17:36 »
i have too much free play in clutch lever, fitted new power clutch & clutch release bearing but stil too much free play in clutch lever after adjustment.
any help much appr.
ash
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline richandhazel
Re: help on clutch adjustment please
« Reply #1 on: 20 April 2003, 18:09 »
Have a look here, this should help you  ;)  :-
http://homepage.ntlworld.com/richandhazel1/Clutch/Clutch.htm
Offline ashmk1
« Reply #2 on: 20 April 2003, 20:23 »
I HAVE ADJUSTED AS FAR AS I CAN GO BUT THERE IS NOT ENOUGH THREAD LEFT ON THE ADJUSTMENT, NEW CLUTCH & CLUTCH RELEASE BEARING FITTED, BUT STILL HAVE PROBLEM. IT SEEMS THAT LEVER ARM IS COMING UP TOO FAR! ANY HELP?
« Reply #3 on: 20 April 2003, 21:09 »
If the lever arm is coming up too far then something is wrong.
How far does the lever arm come up before the pushrod contacts the clutch plate?
I have just fitted my gearbox and my lever arm is reaching the horizontal position and then it stops due to the push rod hitting the clutch plate...........thats about right.
