Author Topic: Speedo issue -- mk2 with a mk3 'box.  (Read 1420 times)
Offline mk14dr
« on: 21 March 2012, 22:33 »
Now then chaps,
I recently had the box go pop on my Mk2 GTi. The replacement box (that is now in, and feeling sweet) is actually out of mk3.
Obviously the electronic speedo wasn't going to work, so the electronic gubbins has been whipped off the box and the standard cable has be put into the speedo drive (just like you would normally) however, the speedo is not working.
Is there something simple that's been missed, or do I need a different cable?
Cheers, Dave.
Offline Diamond Hell
  • Opinions я Us
Re: Speedo issue -- mk2 with a mk3 'box.
« Reply #1 on: 21 March 2012, 23:36 »
020 or 02A?
Cable change, or rod-change?
If it's a rod-change £10 says the plastic drive on the end of the cable has fallen off in the old box.
Offline mk14dr
« Reply #2 on: 22 March 2012, 02:29 »
Rod change.
New cable tomorrow then.
Offline madmanluke
« Reply #3 on: 22 March 2012, 11:34 »
020 or 02A?
As above. I probably had 3 or 4 speedo gears drop in my old gearbox. Never bothered trying to retrieve them out though.
