Golf mk4
Wazzzer
Swapping Turbo
Topic: Swapping Turbo (Read 1360 times)
Dalo Harkin
Swapping Turbo
21 March 2012, 07:18 »
Hi all,
I recently acquired a K03s (thanks Maxxeh
Do I have to do an oil change at the same time / will I lose lots of oil doin the change? I only replaced the oil and filter around 2 months ago
Thanks
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Toby
Car - less
Re: Swapping Turbo
21 March 2012, 07:34 »
I think so . And coolant also - dont quote me on that!
Parsons Performance
R-Tech
Currently down under
stfc_gti
Re: Swapping Turbo
21 March 2012, 08:22 »
Quote from: Toby on 21 March 2012, 07:34
or what?
2002 1.8T GTI AUM, Standard (not for much longer)
MaXXeH
Golf MK5 GTI
Re: Swapping Turbo
21 March 2012, 08:32 »
well really yes, you have to change the oil. The oil return pipe is as low as the sump plug
You could try remove the oil return pipe from the turbo, but expect oil in the face
Dalo Harkin
Re: Swapping Turbo
21 March 2012, 08:42 »
Oil in the face - wont be the first time
Cheers guys
jamie16v
Guest
Re: Swapping Turbo
21 March 2012, 08:56 »
It is possible to just remove the oil return from the turbo. It's tight but doable!
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: Swapping Turbo
Reply #6 on:
21 March 2012, 17:34 »
yup, didn't change my oil when I swapped turbos for the same reason
drain your coolant though, I ended up with a puddle right where I needed to lay lol
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
dan2252
Here all the time
Re: Swapping Turbo
Reply #7 on:
22 March 2012, 00:20 »
if it was me id change the oil and filter just to be kind to your new turbo
MK4 golf 1.8 turbo agu
Golf mk4
Wazzzer
Swapping Turbo
