Author Topic: rear disc conversion  (Read 3905 times)
Offline dazfx
« on: 20 March 2012, 15:47 »
Hi guys need some help!
I'm wanting to convert the rear of my cabriolet
To discs but am a. Bit confused as to what parts I need?
I know that I need to change the rear beam but which
One do I use?
I want to keep my 4 stud, so would this mean using an early mk3 gti one?
Or can I use a mk2 one?
 Also which brake hoses will I need the mk3 gti or mk2 gti?
Any help greatly appreciated
Thanks
Daz
Offline madmanmart
Re: rear disc conversion
« Reply #1 on: 20 March 2012, 17:40 »
One do I use?
Thanks
Daz
Ive done this to my TDI, I used:
Mk3 GTI Beam, hoses, handbrake cables, pads.
Mk2 GTI Disks
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline dazfx
« Reply #2 on: 20 March 2012, 18:11 »
This is what confuses me, isn't a mk3 gti 5 stud?
Or are the early ones 4 stud later ones 5 stud?
Offline madmanmart
« Reply #3 on: 20 March 2012, 20:20 »
All Mk3 GTI are 5 stud.
The wheel screws into the disk, so in effect the disc is the hub.
A Mk2 disk is direct swap but 4 stud.
Offline dazfx
« Reply #4 on: 20 March 2012, 20:45 »
I see thank you for clearing that up and thanks for
The help
Daz
Offline Dogbot
« Reply #5 on: 20 March 2012, 20:48 »
Just done this to the wife's lupo but swapped for polo GTI brakes, I didn't do the beam just swapped the stub axles over, I would assume the mk3 will be no different.....
Offline mad4vws
« Reply #6 on: 20 March 2012, 21:06 »
ive also done this to my tdi but have got 5 stud set up alll round from a mk3 16v ..
you can get a complete rear beam from a mk2 gti and change it from drums to disc's ...
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 20 March 2012, 21:09 »
you could also use a 2.0 vento or cabrio (with rear discs) set up.........which is basically a mk2 set up
Offline dazfx
« Reply #8 on: 20 March 2012, 22:13 »
So as its a cabriolet which stub axels would I use mk2 or mk3?
Boneybradley you say its basicly a mk2 set up so would mk2 stud axles fit the mk3 cabrio?
Daz
« Reply #9 on: 20 March 2012, 23:53 »
Daz
Yes mk2 stub axles and discs, don't forget new wheel bearings as well.
