Author Topic: Carbonio Carbon Fiber Cold Air Intake  (Read 2631 times)
Offline Murrayedition35
« on: 19 March 2012, 19:31 »
I'm thinking about a Carbonio Carbon Fiber Cold Air Intake for the ED35...thoughts guys... :undecided:
http://www.psituning.com/product.php/15454/carbonio_carbon_fiber_cold_ai
Offline Snoopy
  • Moderator
  • Geoff.
Re: Carbonio Carbon Fiber Cold Air Intake
« Reply #1 on: 19 March 2012, 19:43 »
You may have more luck asking on the mk5 forum as the edition 35 uses the same older unit as the edition 30 mk5. Theres bound to be a welth of knowledge about what works on that engine over there.
Current Garage:
35+ years of GTI ownership.
« Reply #2 on: 19 March 2012, 19:46 »
Thanks will do... :smiley:
Offline ScottA
« Reply #3 on: 19 March 2012, 22:00 »
I'll be interested to know if anyone has fitted this CAI on the 2.0 TSI GTI (not Ed35)
Offline Neil gti
« Reply #4 on: 20 March 2012, 06:34 »
I fitted the Carbonio on mine the same time i put Milltek on, no nasty induction roars with this kit, the only time you can hear it is in built up areas were you can hear it quietly sucking away, and when giving it some and lift off you get a nice dumping sound coming back through the filter,
The Carbonio is the only filter i've used on my last 3 cars so i can't compare it to any others ? Would i buy one for my next car....Yes i would   :smiley:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline ScottA
« Reply #5 on: 20 March 2012, 08:27 »
Thanks Neil, sounds good.
Offline KennyGTI
« Reply #6 on: 21 March 2012, 15:54 »
x2 on all what Neil says..........plus it looks good!  :wink:
APR Stage 2+
Offline mkviken
« Reply #7 on: 21 March 2012, 18:01 »
can't comment on the carbonio but im not impressed with my dabble into the world of GTI intakes. will be sticking with the standard air box/foam panel filter/silencer grid removed.
IMO the car runs smoother with the standard air box, especially at lower rpm and the sound is better.
Golf GTI 7.5 230 white silver
Offline gman86
« Reply #8 on: 22 March 2012, 12:53 »
I have an ITG intake on mine and it seems to do the business. Doesn't feel as "throttled" at the higher RPMs. That's with a Stage 1 bluefin.
