Author Topic: Lowering springs twanging! - SOLVED!  (Read 1190 times)
Offline Big Tone
« on: 19 March 2012, 07:18 »
Since fitting new springs, the passenger side rear spring twangs when I shift the weight of the car from passenger side to drivers side, when moving slow, especially on uneven ground, drivers side is fine, spring seems to be in the correct position and is secure, just this noise that its doing my nut in.
Anyone had/solved this?
« Last Edit: 25 March 2012, 16:34 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline JimBR
Re: Lowering springs twanging!
« Reply #1 on: 19 March 2012, 08:16 »
Top mount bearing probably mate
Offline Big Tone
« Reply #2 on: 19 March 2012, 09:17 »
Replaced all top mounts 6 months ago, looked fine when I fitted the springs.
Offline Paul81
  • 2002 GTI Turbo
« Reply #3 on: 19 March 2012, 10:16 »
I've noticed this with mine as well, sometimes happens to the front springs when i turn the wheel.
Is it a sign of a problem?
Mods - Tinted windows, Mk8 Polo aerial, BBS RS2 alloys, -40mm Koni springs, Bilstein b4 shocks, VRS steering wheel, anni roof spoiler, R32 front bumper, rear anni valance, R32 side skirts.
Offline harlemex
« Reply #4 on: 19 March 2012, 17:26 »
I had this; I left it and it went away eventually as the spring breaks in
Offline Big Tone
« Reply #5 on: 25 March 2012, 16:33 »
Sorted, just jacked her up to discover the pass side spring was not located correctly in the lower cup!
Correctly positioned now so we shall see.
