Author Topic: dump valve for 51 plate 1.8t sport passat  (Read 2288 times)
Offline gti gaz
« on: 18 March 2012, 21:44 »
hi ok so am looking in to a dump valve for my 51 plate 1.8t sport passat which is the best to buy??
have been offered a forge one from a 1.8t golf are they the same?? have tried a couple of forums and not had much feed back as of yet and the one i have been offered is quite cheap so thought id ask
hears
gti gaz
 Any one in cornwall lets sort more meets!!!!
Offline thatwillis
Re: dump valve for 51 plate 1.8t sport passat
« Reply #1 on: 18 March 2012, 21:48 »
Offline gti gaz
« Reply #2 on: 18 March 2012, 21:54 »
hi i have been offered a Splitter, a Recirculation and Blow Off Valve as in that thread tink i might give it a go can always remove it and sell it on again as far as i know its come off a rear ended golf and only done about 10k since fitted
« Reply #3 on: 18 March 2012, 21:58 »
Stick with a Forge 007p, wiill be fine and not cause you any issues unlike a dump valve.
Offline gti gaz
« Reply #4 on: 18 March 2012, 22:05 »
will the other cause problems?  have also looked at a 007p was just offered this one cheap
Offline gti gaz
« Reply #5 on: 18 March 2012, 22:25 »
also forgot to add am i right in saying the 007p is very quiet??
Offline SoundillusioN
« Reply #6 on: 18 March 2012, 23:29 »
Quieter than some Jap car running 500bhp yes....  1.8 20VT's don't like having all their excess boost pressure released, it's designed to run with a recirculating (diverter) valve so I believe the 007p is your best shot without upsetting the motor.
« Reply #7 on: 18 March 2012, 23:30 »
Yes it is, but any normal dump valve with cause you hassles.
Offline dave-oz-90
« Reply #8 on: 19 March 2012, 21:49 »
I have the 007p for my mk4 gti and it's fairly loud when using the turbo. Not excessive but you get looks when you give it some  :smiley:
Offline gti gaz
« Reply #9 on: 19 March 2012, 22:19 »
007p purcshed today will be in the post in the morning anyone got any ideas on cheap ish mods for passat face lift a baby due very soon so funds are a wii bit low and the gti is still resting in the work shop
