Author Topic: OIL LEAK! pipe near turbo or diverter valve??  (Read 79886 times)
Offline EyeballPaul
Re: OIL LEAK! pipe near turbo or diverter valve??
« Reply #100 on: 24 October 2012, 22:37 »
Well Snoopy here is the info on what the dealer replaced,
Tube £15.63- V06J1013213
Separator £53.65- VO6H103495
all it said on the info was, found leak replacds crank breather and breather pipe. Not sure if the separator was the whole fine oil separator. Will have to run it abit longer to make sure it is all ok, but so far so good.
Good luck on Friday
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #101 on: 24 October 2012, 23:36 »
Thanks, for the info I'm going to add it to the info I supply them on friday  :evil:
fingers crossed we all get it fixed. :undecided:
« Last Edit: 25 October 2012, 10:12 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline EyeballPaul
« Reply #102 on: 25 October 2012, 08:01 »
Im going to draft a letter this weekend to VW UK about this issue, including the way the garage i dealt with in may dismissed the problem as "nothing to worry about". I was in warranty then, so it could have been sorted at no cost to me, which is the most annoying thing.
Ill be sure to add the link to this thread, as it seems alot of people are beginning to have very similar problems. Im pretty sure there will be alot of GTI owners out there that haven't realised they have this problem yet.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #103 on: 25 October 2012, 11:51 »
Tube £15.63- V06J1013213 is that correct or is it 06J103213 ?
Current Garage:
Offline EyeballPaul
« Reply #104 on: 25 October 2012, 14:23 »
Ill check that number later, i may have written it down wrong
Offline EyeballPaul
« Reply #105 on: 25 October 2012, 18:45 »
Snoopy you got it right, i put an extra number in originally for some reason
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #106 on: 25 October 2012, 20:00 »
Thanks just writing my info for the dealer at this moment.  :smiley:
Current Garage:
Offline EyeballPaul
« Reply #107 on: 25 October 2012, 20:35 »
Lets hope its pretty straight forward, are you still in warranty?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #108 on: 25 October 2012, 20:36 »
Yes just.
If it was not i would be doing it as i use to do this sort of stuff years ago.
Just fixed our Ibiza for example, new cat, CV joint, front dampers, drop links, EGR valve clean, cambelt and main service.
« Last Edit: 25 October 2012, 20:55 by Snoopy »
Current Garage:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #109 on: 26 October 2012, 18:23 »
Well,
Collected the car, they have done a "temporary repair" and ordered in the air intake pipe (i asked what exactly she.just showed me it said air feed intake pipe) so it needs to go back in next wednesday for that fitting. :undecided:
Car stunk of oil on way home, heater on made it worse so had to turn that off. :undecided:
So the GTI will be parked up again till next wednesday and the trusty SEAT leon used again.
« Last Edit: 26 October 2012, 18:33 by Snoopy »
Current Garage:
