Author Topic: cigarette lighter not working  (Read 5726 times)
Offline ashking11
« on: 17 March 2012, 20:50 »
any body had this problem?
Offline Keithuk
Re: cigarette lighter not working
« Reply #1 on: 17 March 2012, 20:57 »
It only works with the ignition on.
Check the fuse 42 (20 amp) Mk6 Fuse Locations
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline ashking11
« Reply #2 on: 17 March 2012, 21:29 »
checked both the 20 amps seem fine!  i have TDI by the way....the fuses are next to the battery
« Last Edit: 17 March 2012, 21:33 by ashking11 »
Offline Keithuk
« Reply #3 on: 18 March 2012, 03:06 »
Which TDI and what year?
There are different fuse/relay boxes on the mk6.
Autodata shows:
Engine bay - type 1 -05/2009
Engine bay - type 1 05/2009-11/2009
Engine bay - type 1 11/2009-
Engine bay 1 - type 2
Engine bay 2 - type 1
Engine bay 2 - type 2
Fascia 1 -05/2009
Fascia 1 05/2009-11/2009
Fascia 1 11/2009-
Fascia 2
You could add your car spec to your signature then user won't need to ask?
Offline ashking11
« Reply #4 on: 18 March 2012, 07:26 »
Autodata shows:
Fascia 1 -05/2009
Fascia 1 11/2009-
Fascia 2
okay i wll its a 1.6 tdi 2009 plate
Offline Keithuk
« Reply #5 on: 18 March 2012, 17:57 »
Autodata shows:
Fascia 1 -05/2009
Fascia 1 11/2009-
Fascia 2
But if you read what I wrote there are 3 version in 2009 when was your built, early, middle or late?
