Author Topic: gearbox oil replace  (Read 2533 times)
Offline devilscaff
  • allways up for alaugh
gearbox oil replace
« on: 17 March 2012, 07:49 »
probably asked before but having a blonde momment where is the fill up plug on my mk2 16v gearbox?
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: gearbox oil replace
« Reply #1 on: 17 March 2012, 08:39 »
It's on the side nearest the front of the car. Fill it up until oil starts to come out.
Offline daveybwoy
« Reply #2 on: 17 March 2012, 20:17 »
As said above but if its an early box (pre 89 I think) you need to fill upto the filler hole, then remove the speedo cable and add 0.5 of a litre through there.
Offline theclash
« Reply #3 on: 17 March 2012, 21:15 »
Make sure you can undo the filler plug before you drop the oil  :wink:
Offline devilscaff
« Reply #4 on: 18 March 2012, 08:32 »
Ok thanks for the last tip
Offline devilscaff
« Reply #5 on: 20 March 2012, 17:29 »
just got round to changing the oil.The old stuff looked like the original (160000miles)replaced with castrol 75-90 and wynns gear oil treatment and already feels so much better,not even noticed any 2nd gear crunch and must have been the easiest job done so far thanks for the great advice.
Offline speedycoolboy
« Reply #6 on: 20 March 2012, 19:18 »
Hey, just wanted to know if you had to take off the wheel, and where you got your oil from? I'm thinking of doing mine its got about 86k on the clock.
Thanks
« Reply #7 on: 20 March 2012, 19:23 »
Also how much oil did you use? and where did you get the oil plug washer/seal from (if you replaced it)
Thanks
Offline devilscaff
« Reply #8 on: 20 March 2012, 19:36 »
got the oil on eBay a good result, didn't replace the seal as there wasn't one.took the passenger wheel off but you have to make sure the car is level then refilled until it just started to come out again as advised by another forum member roughly about 1 1/2 litres plus there was 125ml of treatment.
« Reply #9 on: 20 March 2012, 21:41 »
Ok, and when you took off the wheel, did you then lower the car to what it would normally be (still on the jack) or did you jack up all 4 corners?
Sorry for the stupid questions
Thanks
