Author Topic: Urgent rear seat belt help  (Read 556 times)
Offline houston
« on: 16 March 2012, 15:14 »
Cleaning the car ready for its mot and i removed the rear seats, put them back and now the centre seat belt that comes out of the top of the back rest won't wind back, it's locked no matter what i try, has anyone got a diagram of the latch so i can find it, don't wanna start picking stitching off my recaros to find I don't need to
Offline houston
Re: Urgent rear seat belt help
« Reply #1 on: 16 March 2012, 16:37 »
all sorted, phew!
if anyone else is having this problem, the inertia reel wont work unless the seat is at the installed angle, so once the seat is out it will lock, if you pulled on the belt (like i did) then put the seat at the right angle, pop the 2 plastic clips off where it goes into the seat and use a screwdriver to roll the reel back a bit and this should release the latch and then you can pull the belt back out, easiest to do this when its back in the car.
anyone removing the seat in the future, pull the belt out a bit and tie a knot in it so you dont have this headache
