Author Topic: What the hell are these guys taking?  (Read 2694 times)
Offline ALBEEEEY
« on: 15 March 2012, 18:42 »
ok so I know I should have taken the wheel off but it was gettin dark and didn't have time but yeah what is this? shock absorber? lowering spring (can't see any spring so prob not)?
as you can tell I have no experience with suspension, have googled it but not a lot of answers . . . :undecided:
top
label
hope someone with some experience can help???
thanks in advance  :grin:
« Last Edit: 15 March 2012, 19:35 by richw911 »
-Gone but Not Forgotten 2000 MK4 GT TDi
- Looking for a MK2 8 valver
Offline Toby
  • Car - less
Re: What the hell is this?
« Reply #1 on: 15 March 2012, 18:43 »
looks like  a after market shock? obviously it was on the rear.
« Last Edit: 15 March 2012, 18:45 by richw911 »
Currently down under
Offline ALBEEEEY
« Reply #2 on: 15 March 2012, 18:45 »
yeah rear wheel, was pretty sure it didn't look standard . . .
« Last Edit: 15 March 2012, 18:46 by richw911 »
jamie16v
« Reply #3 on: 15 March 2012, 18:53 »
it`s a continuem transfunctioner!
Offline Steve_PD
« Reply #4 on: 15 March 2012, 18:59 »
If you don't know what it is you really shouldn't be touching it :lipsrsealed: :grin:
Offline richw911
« Reply #5 on: 15 March 2012, 19:00 »
Ah do you remove it with a left handed glass socket?
jamie16v
« Reply #6 on: 15 March 2012, 19:01 »
no, just leave it well alone!...
Offline richw911
« Reply #7 on: 15 March 2012, 19:04 »
 :shocked: OK I think I have a problem I've found four of the dam things.
jamie16v
« Reply #8 on: 15 March 2012, 19:08 »
no mate, the ones on the front are called flux capacitors! they are the ones with a coil which conducts the High Tensile electric charge which thrusts you into the future! should only do this on a full tank though as they are very thirsty and could leave you stranded in the future where all the shell optimax has exhausted its supplies! you`ve been warned!
Offline cullygti
« Reply #9 on: 15 March 2012, 19:10 »
:wink:
guess its not got a foo foo valve on them otherwise you would be in BIG trouble  :laugh:
