Author Topic: fitting brembo 4 pots to mk4 golf  (Read 2317 times)
Offline rabbit1973
« on: 15 March 2012, 11:42 »
hi ..... fitting brembo front callipers of a seat leon cupra r to my golf mk4  and was wondering if i need spacers to make them fit ?  im running 18" with ET 35 offsets ???
« Last Edit: 15 March 2012, 11:59 by rabbit1973 »
Offline barrym381
Re: fitting brembo 4 pots to mk4 golf
« Reply #1 on: 15 March 2012, 12:09 »
you should be ok  :undecided:
Offline rabbit1973
« Reply #2 on: 15 March 2012, 12:13 »
thanks Barry  :smiley:
Offline jonrandom
« Reply #3 on: 15 March 2012, 16:28 »
When I fitted mine the banjo bolt on the end of the brake line had to be changed because of the thread. Ive got Hel braided brake lines but im guessing you will have to change the banjo to.
The standard golf calipers are M10x1.5 where as the brembos are M10x1 what Hel told me and they fitted perfectly.
http://www.clubgti.com/forum/showthread.php?t=242618
Offline km
« Reply #4 on: 15 March 2012, 20:12 »
i had huge problems getting my alloys to fit over the caliper. unfortunately i can't give the alloy et as i don't know, but i had to wait days for spacers/bolts. so just make sure you can clear the calipers before fitting if you need your car for transport etc!  :undecided:
« Reply #5 on: 16 March 2012, 00:12 »
Some wheels clear others don't, offset does not really matter.
