Cosmetic and bodywork matters
sill trim adhesive
Topic: sill trim adhesive (Read 1731 times)
seanvw76
sill trim adhesive
14 March 2012, 21:45 »
just had to have 2 new sills welded on my mk3 and now need to put all the plastic trims back on.
whats the best adhesive,the double sided foam sticky tape stuff or the mastic type stuff from a gun.
cheers sean
Thom89
Forum addict
Looking for an "Icebreaker"
Re: sill trim adhesive
14 March 2012, 23:56 »
Do not use PU sealers, or equivalent Sikaflex, these products are designed for gap filling/sealing
Windscreen bonding adhesive is the way to go, use it with the primer thats supplied, and a 1cm deep "V" cut into the end of the application nozzle, so the sealer comes out sideways, this makes application easier.
http://www.ebay.co.uk/itm/WINDSCREEN-GLASS-REPLACEMENT-BONDING-ADHESIVE-GLUE-CAR-/220435515414?pt=UK_Body_Shop_Supplies_Paint&hash=item3352fb0816#ht_1148wt_946
Thom
sill trim adhesive
