Author Topic: 99T 1.8 GTi Starting problems  (Read 1901 times)
Offline milesgti
« on: 14 March 2012, 00:05 »
hi all - I have recently purchased a great golf and i love it only 1 little problem as follows
went to look at the car had a good long test drive on my own during which time i must have stopped and started it 4 or 5 times no problems, did the deal car started fine drove home (100 miles) drove fine stopped for food car would not start! turned over fine but did not even try to fire into life. tried over and over again then gave up got out and made a call for help. went back to the car tried again and it started straight away!
it has been fine no problems for 5 days lots of trips stop and start picking up and dropping off kids, again this morning fine finished work started no probs drove home picked up son to go to football turned it off an hour later same problem returned (As above) in the end i got out locked it up and walked away for a few minutes i came back and tried again and it started. from here a 5 mile trip to collect the dog turned the car off got the dog and again started no probs.
went home & Dinner then had to go out to get bread and again would not start, thought f"*k it i'll take the wife's car locked up and went in search of her keys which i could not find so when back to the golf and it started! Went to asda came out started fine got home half hour later had to go and pick up the Mrs and started no problems got to the Pub and the bloody thing would not go again called a mate he gave us a lift home i grabbed a rope and we went back to tow it home jumped in turned the key and she started.
sorry to go on a bit but i'm stuck has anyone come across anything like this before? any help / advice ?
Offline barrym381
Re: 99T 1.8 GTi Starting problems
« Reply #1 on: 14 March 2012, 00:11 »
could be as simple as a temp sensor or a number of things buy a cheap code reader of fleebay see if any codes come up
Offline james2
  • No scammers please.
« Reply #2 on: 14 March 2012, 00:16 »
its hard to say ,my car did this once in the 4-5 years iv owned it / same modle as yours. Scan it for fault codes. Crank shaft sensor , i would put my money on. Give it a good service ie oil + filter, air filter and new spark plugs (ngk platinum PFR6Q). I thought it was funny it didnt start ,after going to the pub . :laugh:
« Last Edit: 14 March 2012, 00:23 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline milesgti
« Reply #3 on: 14 March 2012, 10:39 »
Thanks for the info - code reader ordered!  :smiley:
Offline richw911
« Reply #4 on: 14 March 2012, 10:42 »
Crank sensor or fuel pump relay  :wink: Post up the codes when you have them  :smiley:
Offline milesgti
« Reply #5 on: 16 March 2012, 16:21 »
Ok the postie finally turned up at 3pm  :angry: with my code reader so i plugged it in and got the following!
18010, 17953, 17973, 00670, 01165, 16706
I guess this weeks lotto numbers are hidden in there some where and also 16706 is the camshaft sensor but what about the rest and ideas?
all help gratefully received thanks
Offline richw911
« Reply #6 on: 16 March 2012, 17:24 »
 8010/P1602/005634  nothing to worry about  :wink:
Power Supply B+ Terminal 30: Voltage too Low
Possible Causes
    Cables on the Battery were removed
    Battery weak (voltage)
    Generator Disfunction
Possible Solutions
    Check Battery Cables
    Check/Replace Battery
    Check/Replace Generator
7953/P1545/005445 - Do a throttle body clean first : http://www.golfgtiforum.co.uk/index.php?topic=87783.0
Throttle Valve Controller: Malfunction
Possible Symptoms
    Increased Idle Speed
    Bucking at Load Change
Possible Causes
    Throttle Body dirty
    Throttle Body Wiring faulty
    Throttle Body faulty
Possible Solutions
    Clean Throttle Body
    Check Throttle Body Wiring
    Check Throttle Body
17973/P1565/005477 - as above  :cool:
Throttle Actuator (J338): Lower Stop not Reached
Possible Symptoms
    Malfunction Indicator Light (MIL) active
Possible Causes
    Throttle Actuator (J338) dirty (carbonized)
    Throttle Actuator (J338) faulty
Possible Solutions
    Check/Clean Throttle Actuator (J338)
00670 - Throttle Position Sensor (G127)
00670 - Throttle Position Sensor (G127): Signal too Low
Possible Symptoms
    Idle Speed Control inactive
    Air Conditioning not working below 2000 RPM
Possible Causes
    Wiring Short to Ground
Possible Solutions
    Check Wiring
    Perform Throttle Body Adaptation
01165 - Throttle Body Control Module (J338)
01165 - Throttle Body Control Module (J338): Adaptation Not Successful
Possible Causes
    Throttle Body Adaptation Conditions not met
    Throttle Body Control Module (J338) faulty
Possible Solutions
    Check for other Throttle Body related Fault Codes
    Check Throttle Body Control Module (J338)
So you need a new Crank sensor, and a throttle body clean and adaptation  :smiley:
« Last Edit: 16 March 2012, 17:27 by richw911 »
Offline milesgti
« Reply #7 on: 18 March 2012, 09:25 »
ok i have a new sensor and am going for it later today! i have had a quick loot and cant see the sensor yet but have to take my son to football.
Any words of wisdom for when i get back would be a great help
