Author Topic: Front washers not working  (Read 4874 times)
Offline Pearce69
« on: 13 March 2012, 16:30 »
Hey all,
Right basically the washers will not work. They only work sometimes when the wipers are on full speed therefore they are not blocked. Iv checked the fuse and relays there all fine. When I pull the stick back it also doesn't engage the wipers. What could this be?
Offline The Mighty Elvi
  • I'm better than you today.
Re: Front washers not working
« Reply #1 on: 13 March 2012, 16:39 »
Probably faulty stalks.
Can you hear the motor pump buzzing every time you pull back the stalk, on every wiper stalk position?
Offline clipperjay
« Reply #2 on: 13 March 2012, 16:42 »
Find a scrappy nick one off a MK3 (it on the body of the water resivour) I did! Just pull it out and just incase cut the power plug if its different from yours so you can splice it up if need be!
 :smiley:
Offline Pearce69
« Reply #3 on: 13 March 2012, 16:48 »
I will have to check, but im pretty sure nothing is happening unless its on the final position then it kinda squirts on and off.
 :smiley:
Does the mk3 stalk fit then or do u mean the sensor part on the washer fluid container?
Offline clipperjay
« Reply #4 on: 13 March 2012, 16:55 »
 :smiley:
I meant pump NOT STALK fella!
Its a plug into type its a pump if yours is on its way out or clogged up it can sometimes come on and off, I thought try a old pump of a Mk3 and plug it into your water tank wire it up job done. If not then take on the stalk by taking stalk off the steering column and clean it up, remove any dirty grease over the years you might be lucky?
Offline Pearce69
« Reply #5 on: 13 March 2012, 17:16 »
 :smiley:
Ah my bad, Ok well ill take a look at that see if i can clean it first and ill also clean up the stalk before getting a new pump. Thanks for ya help anyway. Is there anything else it could possibly be? gotta sort it asap as i need to get it mot'd
Arron
Offline Pearce69
« Reply #6 on: 13 March 2012, 17:20 »
If it was the pump would it not spray on and off in all positions not just the fastest?
Offline clipperjay
« Reply #7 on: 13 March 2012, 17:22 »
so it does spray trickle or full force?
If it sprays full force strip down the stalk clean it up otherwise start looking for one I'm sure GSF should do a replacement?
« Reply #8 on: 13 March 2012, 17:26 »
Disconnect the water tubes from the pump and then test.  If the pump works then its a fault with your stalks.
Offline Pearce69
« Reply #9 on: 13 March 2012, 17:44 »
Well the rear works perfect and yh the fron does do full force but its just in short bursts?
