Author Topic: milltek lads  (Read 1999 times)
Offline mk3tony
milltek lads
« on: 13 March 2012, 15:23 »
my 3inch miltek catback rests on my rear axle, is this correct? There isn't a lot of room to move it and the worry is that if its moved up a tiny bit using new mounts that it'll knock the axle. At the moment its resting on the axle and obviously bumps etc are slightly twisting the rear section
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline Toby
  • Car - less
Re: milltek lads
« Reply #1 on: 13 March 2012, 16:12 »
happens on mine aswell  :grin: so friggin annoying! i think when i get it back, ill try and heat wrap it so if it knock's it wont be as noticable! or move it much aswell
Currently down under
Offline richw911
Re: milltek lads
« Reply #2 on: 13 March 2012, 19:12 »
It a tight fit mine was knocking with people in the back Milltek re fitted it for free with new SS clamps its spot on now  :smiley:
Offline mk3tony
Re: milltek lads
« Reply #3 on: 13 March 2012, 21:23 »
what clamps are you referring to rich? my exhaust was s/h and only came with 1 clamp. its got 2 normal clamps on rear section
Offline richw911
Re: milltek lads
« Reply #4 on: 13 March 2012, 21:27 »
They changed all the clamps for new ones  :smiley: They said a common thing is people don't push the system together properly - they say it should never knock even on a lowered car  :smiley:
Offline mk3tony
Re: milltek lads
« Reply #5 on: 13 March 2012, 21:43 »
hmmm, mine was sitting dead straight but the bend sat on the axle itself nothing could be dine, raising it up would mean the tips were very close to the valance.
Offline richw911
Re: milltek lads
« Reply #6 on: 13 March 2012, 21:52 »
Give Milltek a ring they are very helpful  :wink:
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: milltek lads
« Reply #7 on: 13 March 2012, 22:05 »
can you take it to any milltek dealer to get it sorted mines knocking to?
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline richw911
Re: milltek lads
« Reply #8 on: 13 March 2012, 22:09 »
Not sure about that, I took mine to the Milltek factory, give them a ring they will be able to help you sort it.
Offline symsymma
Re: milltek lads
« Reply #9 on: 13 March 2012, 22:18 »
ok mate ill give em a ring :cool:
« Last Edit: 13 March 2012, 22:20 by richw911 »
