Author Topic: KStar not storing maps when powered down  (Read 2623 times)
Offline tomp
« on: 12 March 2012, 21:39 »
Found out that my KStar unit isn't holding the map settings, if I write a saved map, then turn the car off and start it again then I can't read the unit and have to write the map back into it, if I don't turn the ignition off I can disconnect and reconnect and read the kstar with no problems.
The kstar is running four extra injectors and ignition timing. (Its an 8 injector mk2 16v Turbo) The car is undergoing a full restoration but I really want to get this sorted as the engine is back in fully rebuilt and running sweet.
I have taken the unit apart and am thinking about taking the chip off and reprogramming and fitting a new chip. I am guessing that it just flashes the chip when data is written to it so shouldn't be too hard to change for a new chip as a starting point.
Any suggestions more than welcome!
Offline topher
  • Administrator
  • fully functioning
Re: KStar not storing maps when powered down
« Reply #1 on: 12 March 2012, 21:42 »
i'm not familiar with kstar but i take it there's no internal battery? if not i'd go with the chip idea. non-volatile memory failure perhaps..
Offline Sam
  • Sam I am
« Reply #2 on: 12 March 2012, 21:48 »
Ring vince  :wink:
Offline tomp
« Reply #3 on: 12 March 2012, 21:50 »
That's exactly why I took it apart to see if was something as obvious as an internal battery that only lasted for about 12 years!
The memory failing on the chip was my second train of thought. Luckily my business partner designs and makes circuit boards and programmes his own chips so I am gonna give it to him to read the existing chip and try copying the data, if any, onto a new one. He could probably reverse engineer the whole thing if required!!
I may just give Vince a ring tomorrow Sam...
Offline danny_p
« Reply #4 on: 12 March 2012, 21:55 »
kstar can be twerp when it gets it's arse out.    id ditch it and go full efi
all the VW's have gone bar 1.
Offline tomp
« Reply #5 on: 12 March 2012, 22:04 »
It may come to that, hoping not though as the unit is working, its just not storing its settings....
Offline Sam
  • Sam I am
« Reply #6 on: 12 March 2012, 22:07 »
Stick with it, we are the only ones  :cool:
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 12 March 2012, 22:08 »
doesn't horney have kstar on his track car too?
Offline tomp
« Reply #8 on: 12 March 2012, 22:11 »
Old school tuning (that was once state of the art - windows95 FTW!)  :grin:
Offline Sam
  • Sam I am
« Reply #9 on: 12 March 2012, 22:13 »
He has never answered any of mine or tomps questions so im not to sure he does, I may be wrong though...
