Author Topic: Central Locking...  (Read 1727 times)
Offline 9thwonder
Central Locking...
« on: 12 March 2012, 11:34 »
Right just an easy question i guess.
Is the standard central locking supposed to lock and unlock the boot?
Mine doesnt and i have to do it manually.
Thanks
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Central Locking...
« Reply #1 on: 12 March 2012, 11:44 »
Thanks
Yes - yours is probably seized up Common issue...
Free Off & Grease up the white clip on the lock with the long bar and it should work again!!
For More Info Click To See;
Offline 9thwonder
« Reply #2 on: 12 March 2012, 12:01 »
thanks ill have a look and see if i can see what your on about...i may be coming back for more info lol
Offline 9thwonder
« Reply #3 on: 12 March 2012, 12:45 »
just had a look and i cant see anything white on the boot lock? or am i looking in the wrong place?
Sorry for the noob response.
Thanks
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 12 March 2012, 13:29 »
HAVE YOU TAKEN THE TAILGATE cover off???
The one that covers the wiper motor etc..
Offline 9thwonder
« Reply #5 on: 12 March 2012, 13:37 »
ahh no...i only had a quick look while i was on lunch from work. will have a proper look later on then
Thanks
Offline oakgreener
« Reply #6 on: 12 March 2012, 13:38 »
Take off the trim on the boot lid and you'll see the central locking mechanism with the actuator on the right of the lid and a connecting rod to back of the lock. The rod moves a white plastic thingy to and fro to enable the lock to be pressed against it which operates the de-latching mechanism. It seems like something is not moving freely on yours.
Offline 9thwonder
« Reply #7 on: 12 March 2012, 14:29 »
Thanks for your help guys ill have a look later on and hopefully get it sorted.
Offline Steve_B
« Reply #8 on: 12 March 2012, 19:06 »
Check for rust on the connecting rod. This can cause the mechanism to seize where it goes through a clip. Sand down and as said apply some grease.
