Author Topic: blue led dash bulbs, ebay, any good??  (Read 3954 times)
Offline RIPP3Y
« on: 11 March 2012, 21:54 »
hi,  has anyone fitted these bulbs before??
there only a tenner so im tempted to give it a go as i got no dash lights at the mo.
Cheers :wink:
Offline raferackstraw
Re: blue led dash bulbs, ebay, any good??
« Reply #1 on: 11 March 2012, 22:29 »
no they do not fit. they are slightly smaller and will not make the connection, a bit like the myth of weighted gear shift.
just get the original type. i usually buy mine from a dealers  :rolleyes:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline RIPP3Y
« Reply #2 on: 11 March 2012, 22:45 »
thanks for that,  i came close to buying them.
always worth asking,  :wink:
Offline SoundillusioN
« Reply #3 on: 12 March 2012, 11:20 »
The best method is to solder universal LEDs to the original holders.
Offline chalky white
« Reply #4 on: 13 March 2012, 21:48 »
I think I would be asking why I have no dash lights?
Are you sure it's blown bulbs or no supply to the clocks per se?
Offline hydro187
« Reply #5 on: 25 March 2012, 22:53 »
it could be a blown bulb or the dimmer fingers crossed its a blown bulb
« Reply #6 on: 26 March 2012, 11:38 »
Yes, I had to mention this in the MK2 section... My dash lights wet out, turned out to be a poor connection on the dimmer, changed the switch and all was well.
Give the dimmer a bit of a fiddle, you may find they come back on.  They tend to become weak at full brightness and the connection fails, if you turn it down a little it may work again, if they do, change the switch.
Offline RIPP3Y
« Reply #7 on: 02 April 2012, 23:22 »
 I`ll give that a go in the evening, cheers.
« Reply #8 on: 03 April 2012, 21:24 »
Double check the wire that comes off the rocker cover (Top right corner) to the coil mounting bracket bolt is okay, as this earths the dash clocks too.
Offline RIPP3Y
« Reply #9 on: 03 April 2012, 21:43 »
Ooooo, intresting, i didnt no that, Cheers :wink:
