Author Topic: starter motor problem  (Read 4401 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 09 March 2012, 18:38 »
this has happened twice to me now.
the stater motor has stuck and wont turn at all,the car will only start if you bump start it.
after that the motor is fine until it happens again is it worth dismanteling it and cleaning it all up or just get a new one?
Offline richw911
Re: starter motor problem
« Reply #1 on: 09 March 2012, 18:42 »
Sounds like a burnt spot if so it will need replacing.
Offline (shakey)
« Reply #2 on: 09 March 2012, 18:45 »
will it o well best place and cheapest place rich to get one.
Offline Toby
  • Car - less
« Reply #3 on: 09 March 2012, 18:47 »
Mine sreaches  :grin:
Currently down under
Offline (shakey)
« Reply #4 on: 09 March 2012, 18:49 »
would profer the sreache than it not starting m8 i nearly missed the carling cup final the other week would of not been happy.
Offline richw911
« Reply #5 on: 09 March 2012, 18:54 »
Carparts4less which is owned by Euro car parts but appears to be cheaper even with forum discount!
http://www.carparts4less.co.uk/starter-motor
Even has the same part numbers http://www.eurocarparts.com/starter-motor
« Last Edit: 09 March 2012, 19:16 by richw911 »
Offline rio_gti
« Reply #6 on: 09 March 2012, 19:14 »
im sure there is a how too to recon it.....
http://www.golfgtiforum.co.uk/index.php?topic=151809.0
worth a shot??
Offline richw911
« Reply #7 on: 09 March 2012, 19:18 »
worth a shot??
Wont fix a burnt spot though - a local car electrical specialist may be able to do it cheaper than buying a recon one  :undecided:
Offline boyob32
  • 1.8T
« Reply #8 on: 10 March 2012, 06:55 »
Seems obvious but have you checked the wiring too? Mine was playing up and luckily it turned out to there been a poor connection to the starter.
Offline (shakey)
« Reply #9 on: 10 March 2012, 10:47 »
might have a look at that now,because the glowplug light is just flashing like the battery is dead but its not.
