Author Topic: Mk4 1.8T AUM stage 1 remap question  (Read 3581 times)
Offline AntMk3GTi
« on: 09 March 2012, 16:15 »
Hi
I've recently got a MK4 1.8t 150bhp with the AUM engine. Am I right in saying this has the K03s turbo and a stage 1 remap will see 200bhp?
If so, will it be ok to run the standard clutch set up with 200bhp? Ive got a receipt for a new clutch fitted less than a year ago so it'd be a shame to ruin it so soon if it cant handle the extra power.
Also, I'm planning on upgrading to a fmcl007p diverter valve. Is this a direct replacement, so exactly the same size as the stock one etc?
Thanks
Offline iowm3
Re: Mk4 1.8T AUM stage 1 remap question
« Reply #1 on: 27 April 2012, 00:35 »
Id like to know this also as iv just picked up a 2001 golf turbo with AUM engine?
Offline barrym381
« Reply #2 on: 27 April 2012, 00:40 »
get a forge 007 then have your car mapped, an the clutch should be ok   :smiley: an yes the aum has k03s
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #3 on: 27 April 2012, 14:29 »
I second what barrym381 says. I have a 2001 Aum, and just before I had it remapped the gear box went, so I had it replaced as well as the clutch and fly wheel (oem parts). Touch wood, my clutch has been fine since the remap, which was done about 22 months ago. What you are most likely to need to replace after a remap will be the pcv pipework under the inlet, and the diverter valve.
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline shaft69
« Reply #4 on: 28 April 2012, 16:06 »
Be ok mine runs 231bhp and 250torque my clutch is fine (touch wood) still original on from new, and drive mine hard too.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
