Author Topic: running prob  (Read 1122 times)
Offline dam088888
running prob
« on: 09 March 2012, 15:00 »
When I'm driving and change from 1st to second then put foot straight down it like kangaroos till I let off and so it smoothly same if its parked up and pop the bonnet and rev it by hand short and sharp its like its holding back or spluttering at first. Need to change alternator tensioner as its rattely at the mo so not sure if this would affect it but its fine if you change gear and slowly go up the revs anyone got any ideas
2000 agu 1.8t lowered 55mm,cream mirrors and wheels,stage 1 map, forge 007p,
Offline richw911
Re: running prob
« Reply #1 on: 09 March 2012, 15:08 »
Boost leak faulty MAF  :undecided:
Any fault codes?
Offline dam088888
Re: running prob
« Reply #2 on: 09 March 2012, 15:29 »
Not plugged it in yet also unplugged maf still same to be fair does sound a little like a air leak from some where but its fine if you get on the throttle smoothly only happens of you put foot hard down after changing gear straight away
Offline richw911
Re: running prob
« Reply #3 on: 09 March 2012, 15:41 »
Have you done a throttle body clean?
Offline rio_gti
Re: running prob
« Reply #4 on: 09 March 2012, 15:52 »
Sounds like too much air not enough fuel at that slit second check for split pipes as rich said boost leeks etc
Offline dam088888
Re: running prob
« Reply #5 on: 09 March 2012, 17:46 »
Read some where it could be temp sender now I changed it not so long ago for a xheap ebay one well in the end it turned out it was stat so i kept the gen one. So after reading it could be that I stuck the gen one back in and took for a spin and seemed ok so ill see how it goes. But could temp sender cause the prob I mentioned
Offline rio_gti
Re: running prob
« Reply #6 on: 09 March 2012, 17:50 »
Tryin I push mOre fuel in cos it Thinks it is cold but chokes it instead
