Poll
can cars ever b simple
not a chance
1 (50%)
no  not for the sunday diy
1 (50%)
Total Members Voted: 2
Author Topic: 2001 polo 1.4 mpi  (Read 2577 times)
Offline staffyman
2001 polo 1.4 mpi
« on: 07 March 2012, 20:01 »
Ive  got a 2001 1.4 mpi polo eml came on about 2 month ago  error code p1348 un p1349 po300 po301 first open circuit stage 1un 2  un multiple misfire  cylinder 1misfire detected replaced coil leads un plugs reset light car ran fine  now lights come back on wiv same codes any checked it again  un done a readness test it came wiv cat fail evap system fail heat 02 sensor fail am i rite in thinkin there due   coil breakin down again  if it is the coil any help wud b welcomed
Offline JC
  • Back in the North.
Re: 2001 polo 1.4 mpi
« Reply #1 on: 07 March 2012, 20:08 »
 :huh:
a plo forum would be a better bet, would it not
and hello  :smiley:
Offline staffyman
« Reply #2 on: 07 March 2012, 20:23 »
:huh:
and hello  :smiley:
hi  :smiley its the first time on this site m8 i thought id just ask any help will do its doing my  head in
Offline Andy-H
« Reply #3 on: 07 March 2012, 20:45 »
Lambda sensor??  :undecided:
If you have replaced the coil it seems unlikely it's the same again...................unless you bought a second hand unit.
Was the fault diagnosed at a garage or a code reder of your own?
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline staffyman
« Reply #4 on: 07 March 2012, 20:53 »
hi m8 ive got my own code reader but surely the lambda sensor  code wud av came up
Offline staffyman
« Reply #5 on: 07 March 2012, 21:01 »
the coil un leads all new
Offline Andy-H
« Reply #6 on: 07 March 2012, 21:23 »
Depends really, my old motor was fuelling badly, didn't show any faults pointing towards the Lambda but replacing it cured it.
Not saying it's the definite cure for yours but worth a thought  :smiley:
'91 Tornado red Mk2
Offline staffyman
« Reply #7 on: 07 March 2012, 21:45 »
now u sed that the eml started flashin before it stoped on which i  read it flashes to tell u before damage to lambda or the cat so u might b rite ill get 1 2moz un try
