Author Topic: Engine Transplant lol  (Read 4807 times)
Offline Performance-parker
« on: 07 March 2012, 02:16 »
Hi Guys,
Obviously new here and looking for some advice i want to know If i could fit a 3.5 v8 bmw engine in my Mk2 Golf? and before you ask i know its bmw not vw but i got one lying in the garage and i want to have some fun with it  :evil:
Advice?
Anyone else tried something similar?
Links would be most welcome  :smiley:
Many thanks,
                 Parker
IF YOU'RE NOT FIRST, YOU'RE LAST.
Offline JonLeeper
Re: Engine Transplant lol
« Reply #1 on: 07 March 2012, 08:12 »
Anything is possible, not easy but possible.  There are two options that you could examin, in my opinion.  The first would be a front engined rear wheel drive Mk2.  The obvious problems with this are space (not sure if the v8 will fit between the bulkhead and the grill), layout (the Mk2 is designed for a transverse front wheel drive not a longditudinal rear wheel drive), and the rear suspension (beam not indipendant).  All of these could be solved, by using a spaceframe chassis for example, but not easilly or cheaply.  The second option would be to make a mid-engine rear wheel drive Mk2.  This has been done in the past, although not with a BMW engine to my knolledge, and so is achievable.  It would require a new subframe to be manufactured to take the engine and gearbox and then welded into the car.  Again this iis not easy, quick or cheap to do.
So inessence it is possible IF you have deep enough pockets, or sufficicent skills and access to the correct machines.  One thing is certain, it will not be quick or easy to do.
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 07 March 2012, 09:06 »
If you could put a BMW 3.5 V8 in your MK2  :rolleyes:  :lipsrsealed:  It probably wouldn't go around corners.
Offline SoundillusioN
« Reply #3 on: 07 March 2012, 09:16 »
I've seen a Range Rover V8 shoehorned into a mini so anything is possible.   Driver had to sit in the back pretty much but it worked, well, it moved.  Things like this are usually show ponies over something functional.  Do want to be able to drive it or drag it?
« Reply #4 on: 07 March 2012, 13:36 »
Your looking at major work, spaceframe is going to be a good idea even if you could do the conversion your looking at major hassle with the DVLa to get it on the road.
« Reply #5 on: 07 March 2012, 13:39 »
Bit like that Bi-Turbo, Audi Powered, Mid-Engined MK1 that never seemed to get finished and went up for sale. ... I suspect it couldn't be made road legal.
« Reply #6 on: 07 March 2012, 13:45 »
Spot on :afro: dealing with the DVLA is not going to be easy
« Reply #7 on: 07 March 2012, 13:47 »
I wonder where that MK1 is now..  :undecided:
« Reply #8 on: 07 March 2012, 13:50 »
Not sure, have not noticed it on ebay for ages  :undecided:
Offline barrym381
« Reply #9 on: 07 March 2012, 17:51 »
buy an old e30 an throw your engine in that :evil:
