Author Topic: Head unit went bang  (Read 701 times)
Offline Dave_IOW
Head unit went bang
« on: 06 March 2012, 23:34 »
Now i have no audio   :grin:
What should i be looking at, cant work out which fuse it is, apparently might be 2?
No fuses in back of headunit itself, (non OEM and rubbish tbh) could this of had it?
Wiring a bit of a mess behind there, got 2 components in doors run off a small amp and 2 rear speakers working off head unit if that helps   :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Re: Head unit went bang
« Reply #1 on: 07 March 2012, 00:00 »
Check for power to the headunit with a testlamp that will confirm if the wiring / fuses are ok.
Offline johnomk4
« Reply #2 on: 07 March 2012, 08:42 »
+1 you should have a constant from the battery, and one feed from the ignition.  :wink:
Offline Dave_IOW
« Reply #3 on: 07 March 2012, 10:08 »
Read something about removing 2 fuses and must both be out at the same time?
