Author Topic: 2nd gear crunch  (Read 4576 times)
Offline devilscaff
  • allways up for alaugh
2nd gear crunch
« on: 06 March 2012, 19:50 »
what can be done to eliminate 2nd gear crunching when cold? on 16v.
(sorry if asked before)
Offline theclash
Re: 2nd gear crunch
« Reply #1 on: 06 March 2012, 19:57 »
I had the same problem on a mk1 2nd gear crunch all the time :sad:
I put fresh gearbox oil and a tube of forte gearbox/diff treatment in and it was 100% better
Offline devilscaff
Re: 2nd gear crunch
« Reply #2 on: 06 March 2012, 20:01 »
Ok thanks think i'l start there then thanks
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: 2nd gear crunch
« Reply #3 on: 06 March 2012, 20:10 »
use search function plenty of info there  :smiley:
Offline bodga
  • F reg GTI 16v
Re: 2nd gear crunch
« Reply #4 on: 06 March 2012, 20:41 »
Syncro on second gear is tired, as above change the gearbox oil for good quality stuff and if that doesnt cure it use double clutch stop the crunch :wink:
http://www.youtube.com/watch?v=pI3cHXnGEx4
Offline devilscaff
Re: 2nd gear crunch
« Reply #5 on: 06 March 2012, 21:35 »
sorry such a slow response got sidetracked on youtube! how much oil do I put in the gearbox?
Offline daveybwoy
Re: 2nd gear crunch
« Reply #6 on: 07 March 2012, 20:12 »
If its a 1990 gear box with the car level you fill until it just runs out of the filler.  On the early boxes the filler hole was lower and you need to remove the speedo cable and add some extra through there.  About 0.5 litres.   Be careful removing the cable.
Offline devilscaff
Re: 2nd gear crunch
« Reply #7 on: 11 March 2012, 08:06 »
Thanks for the advice doing it this week
Offline clipperjay
Re: 2nd gear crunch
« Reply #8 on: 11 March 2012, 11:02 »
Woth checking the selector rods!
You might get lucky just changing some of the worn out plastic joints in the selectors unit
They are cheap plus a weighted rod might help make selection smoother if you dont have one in there already?
VW BUSH
Re: 2nd gear crunch
« Reply #9 on: 11 March 2012, 14:00 »
+1
Worn linkage can make gear changes terrible.
I made new bushes out of Bronze and bought a kit from TSR (i think) which replaced the plastic UJ's with metal ones.
It is one of the best upgrades you can do to a Mk2 :smiley:
If that or the oil change does not help or cure your problem then its a box rebuild :wink:
