Author Topic: Strange Electrical Fault - Non Starter!!!  (Read 958 times)
Offline Procomp
« on: 06 March 2012, 17:04 »
Hi
Looking for some advise on my 1.8T not starting.  I've been doing some work on the suspension so I've had the the suframe down and the uprights off as I've replaced the whole suspension with FK coilovers.
When I've come to start the car, after putting it all back together,  as soon as I put on the ignition on all the warning lights started to flash repeatedly and the car wouldn't turn over or anything.  There are some strange rapid ticking noises coming from the dash and even the throttle body (by the throttle cable) was making a ticking noise when I lifted the bonnet ???  Non of the electrical systems will work on the car at all.
Very confused as to what this could be any ideas...................
Gregg
Offline rio_gti
Re: Strange Electrical Fault - Non Starter!!!
« Reply #1 on: 06 March 2012, 17:05 »
did you replace all the ground wires properly??
Offline Procomp
« Reply #2 on: 06 March 2012, 17:40 »
Hi
Thanks for the info........didn't notice any directly under the car.  Where would it/they be located?
Thanks
Offline richw911
« Reply #3 on: 06 March 2012, 17:49 »
Hi
Thanks
http://mit.edu/dennis/www/vw/grounds.html
Offline Procomp
« Reply #4 on: 06 March 2012, 17:58 »
Cheers....will have a look altho I don't remember undoing anything other than the the brake pad or ABS sensors on the hubs.......
Thats why I'm a little confused.
Out of interest... If the battery was goosed, could it manifest itself in the issue I have?  Will check it in a bit to see.
Offline Procomp
« Reply #5 on: 06 March 2012, 18:34 »
Thanks everyone for the quick response and help........would you believe it it was the battery of all things !!
I thought I'd disconnected everything that would have drained the battery whilst working on the car, but I'd left an interior light on.
Sometimes........it the simple things in life that you have to make sure of being in place so it seems   :smiley:
Gregg
Offline Ashmond
  • Money, b!tches And Boost
« Reply #6 on: 06 March 2012, 18:53 »
Hi
Thanks
You got a link got everything!
Offline richw911
« Reply #7 on: 06 March 2012, 19:35 »
Hi
Thanks
Some things yeah  :grin:
