Author Topic: mk4 golf hub removal help  (Read 3586 times)
Offline jonnyturbo
« on: 05 March 2012, 21:21 »
Is it possible to remove my front hub without removing my wheel adaptor? as I had my pads done last year and looks as tho the mechanic has put my adaptors on with windy gun . And I cnt free 2 bolts off. They are rounded off ( same as gf LOL ) I have tried loads if sockets . Bolt extraction tools and heat and gettin no where . Looks as tho the 2 bolts that are stuck have bitten into the ally spacer . So now thinking can I get the hub off and heat the hub from behind to free it off .
Offline Steve_PD
Re: mk4 golf hub removal help
« Reply #1 on: 05 March 2012, 22:18 »
Drill out the rounded off bolts and use and extractor to get them off or weld a bolt/nut onto it.
Don't really see what heating it from behind will do need to heat the head of the bolt up to release the tension :undecided:
Offline jonnyturbo
« Reply #2 on: 06 March 2012, 20:26 »
Can't weld a bolt to it can aye ? As the spacer is aluminum  :undecided:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #3 on: 06 March 2012, 20:50 »
Your telling me a stud removal tool won't get it out? Get a massive one, drill a hole that is smaller than the stud extractor...Surely that shuold work?
That is a pretty bad situation mate...Sorry mate  :sad:
Offline jonnyturbo
« Reply #4 on: 06 March 2012, 20:59 »
I have just tried then splined sockets with like teeth in in them and they don't work . Haven't tried drilling stud and screwing them extractor tool in
Offline GunnerCP
« Reply #5 on: 06 March 2012, 22:05 »
think i've got a brand new (genuine VW) hub if you're interested?
Offline Steve_PD
« Reply #6 on: 06 March 2012, 22:11 »
yes spacer is aluminium but bolt is steel so weld to the bolt
Offline GunnerCP
« Reply #7 on: 06 March 2012, 22:16 »
just checked and its actually a rear hub so no help! Did have a front but not sure where it is.
Offline houston
« Reply #8 on: 06 March 2012, 22:17 »
take it to a garage, easiest possible way, will save a lot more time messing on when you can give it to someone thatll be able to do it in a few mins.
surprised you cant hammer a smaller socket onto them tho.
johnny were you worrried the spacer will melt with weld? dont be, they take some heat to disfigure.
why do you want the hub off? or is it just for the adadptor?
Offline jonnyturbo
« Reply #9 on: 07 March 2012, 05:59 »
Not worried bout it melting just disforming but if u say they take some heat its ok . It's booked in to garage tomorrow. Just want the adaptor off so I can change all the adaptor bolt to ones with a stronger head . And also gettin wheels powder coated so will need them off so i can put winters on LOL
