Author Topic: help start engine GTI With Mk2 1.8GTI Digifant NOW FOR SALE  (Read 7061 times)
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Hi all i hope you can help. Iv done most of the conversion but down to 4 wires which are in the cabin that seem to come from the ecu.
the colours of the wires are
red-yellow
red-green
and 2 black-yellow
Any one know where i wire these to and what they do as id like to get the engine running.
Thanks folks and sorry for my long absence :smiley:
My dad needs her started asap so he is offering drink money to anyone who can come over and help get it going this weekend. He's not tight either on money  :wink:
His number is 07845472257 David. Give him a bell and arange he's a top bloke
The car is located in Bethersden inbetween Ashford and Tenterden
Please see classified section
« Last Edit: 30 May 2012, 17:06 by G60GTI16V »
Offline SoundillusioN
Re: Mk1 GTI Engine Conversion With Mk2 1.8GTI Digif
« Reply #1 on: 05 March 2012, 14:02 »
red-yellow
red-green
and 2 black-yellow
Not good enough!  :tongue:
red/yellow - fuel pump trigger
red/green - starter motor live
yellow/black - ecu power (from ecu relay)
Might be worth checking with a mk2 person though.
« Last Edit: 05 March 2012, 14:04 by SoundillusioN »
Offline G60GTI16V
« Reply #2 on: 15 March 2012, 16:30 »
thanks for the info, these have been wired up now but when its cranked over it only gives 1 spark? any ideas?
« Reply #3 on: 15 March 2012, 16:42 »
How do you mean?... Only one plug sparking?
Offline G60GTI16V
« Reply #4 on: 15 March 2012, 17:02 »
my dad just said there is only one spark when its cranked so im guessing it could be one on all or one from the coil?
« Reply #5 on: 15 March 2012, 17:12 »
Hmmm, not sure.. would need clearer info on symptoms.
Offline G60GTI16V
« Reply #6 on: 17 March 2012, 09:13 »
the red/yellow - has been wired to fuel pump trigger
red/green - has been wired to starter motor live
2x yell/black cables have been wired to power so now there is power to ecu
when the key is turned and held at crank position there is one cycle of sparks to each plug then nothing and also there is no power to ecu...?
« Reply #7 on: 17 March 2012, 09:31 »
Strange, probably something for the mk2 boys again.  :undecided:
Poorly coil maybe?
Has it got an imobiliser?
Offline G60GTI16V
« Reply #8 on: 17 March 2012, 09:44 »
it did have an immobiliser but i took the ignition barrel rear housing off and ripped the immoboliser out and wired it back up as norm to the ignition.
 :sad:
« Reply #9 on: 17 March 2012, 09:47 »
 :sad:
Did it work OK before this?  :lipsrsealed:
