Author Topic: Do you bleed your own brakes?  (Read 3116 times)
Offline rockmonkey69
Re: Do you bleed your own brakes?
« Reply #10 on: 05 March 2012, 13:39 »
I have to do it myself, if I take it anywhere I'm worried they will scratch the finish on my caliper when taking my wheels off because there's very little clearance between the spokes and the caliper. Most places don't bleed the calipers starting from the corner with the longest distance of line from the servo.
Offline stainesy
« Reply #11 on: 05 March 2012, 16:15 »
If so any tips?
Or do you just take it somewhere? understand they can be a biatch, and only one "success" on the How To in the maintenance section.
Quite strange this thread is on here as I bled my brakes about 2 hours ago. Changed front pads and pedal felt sponges after so I decided to bleed the brakes. Does. Feel abit spongey now but probly as pads need to bed in.
Offline houston
« Reply #12 on: 05 March 2012, 20:06 »
the golf system is no different to any other car, just for some reason it responds better to an eezi bleed kit.
ate superblue is canny cos you can see when youve bled the lines but theres been some reports of sqealing with this fluid, cant speak from experience here tho
make sure you do the clutch and the 2 bleed nipples on the side of the brake reservoir too
ive done 2 golfs so far and both were trouble free (wont mention the mk5 i attempted to fix after my mate had tried)
Offline old_n07
« Reply #13 on: 05 March 2012, 20:26 »
I always take it to VW as no one ever seems to get it right.
Speak for yourself you tart  :tongue:
Not had any problems using a pressure bleeding kit, just make sure you don't let the resevoir run dry and bleed the master cylinder as well and all is good
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline richw911
« Reply #14 on: 05 March 2012, 21:16 »
lol  :tongue: I dont have the kit, had two places do it and its never as good as VW plus a fliud change at VW is only £30  :smiley:
Offline richw911
« Reply #15 on: 05 March 2012, 21:24 »
really? thats pretty damn good!
my friendly mechanic said mmmmm 50?
May have been an offer then?  :undecided:
Offline richw911
« Reply #16 on: 05 March 2012, 21:31 »
maybe they just like you  :grin:
They don't  :lipsrsealed:  :grin:
Offline richw911
« Reply #17 on: 05 March 2012, 21:40 »
do it cheap so you feck off quick  :grin:
That would be more like it  :grin:
Offline tokemk4gti.t
  • 2001 gti turbo :-)
« Reply #18 on: 05 March 2012, 22:58 »
is it really £30 at vw?????? what if i gave them the fluid i want?? i.e race fluid or would they only use there standard stuff??
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #19 on: 07 March 2012, 17:00 »
I got a quote from the stealers yday and they quoted £69.50 ( not sure if that was inc or exc VAT)
Rang a local garage and they said £50, I know where I'm going...after reading about bleeding the 2 under the reservoir in particular and some people missing them do you think it would be arrogant of me to mention it to the garage when I take it in?
