Author Topic: Probably a pretty stupid question.....  (Read 1070 times)
Offline dom
  • Back in a Mk4
« on: 04 March 2012, 18:18 »
Ok, the R32 wheels that I have are genuine VW items, not aftermarket reps, I'm sticking wider spacers on the fronts, am I right in thinking that I need Radius bolts opposed to tapered?
Offline daz veedub
  • Operation 1.8t bolf
Re: Probably a pretty stupid question.....
« Reply #1 on: 04 March 2012, 18:20 »
how wide on the front mate a think 10mm and up should come with the longer bolts required
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 04 March 2012, 18:24 »
Yep radius.
Tapered for aftermarket crap.
Offline dom
  • Back in a Mk4
« Reply #3 on: 04 March 2012, 18:26 »
Daz - I'm getting 10 or 15mm spacers so will need longer bolts, I just want to check that they are going to send me the right ones :wink:
Offline Steve_PD
« Reply #4 on: 04 March 2012, 18:43 »
Radius head bolts and 40mm length will do it for 15mm spacers
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5 on: 04 March 2012, 19:00 »
Yep radius.
OOOh really, would this ring true for almost any wheel be it OEM or after market re makes?
Offline AD1.8T
« Reply #6 on: 04 March 2012, 19:43 »
To be perfectly honest ive used tapered bolts on my V6 tt wheels and my a3 sport ones and theyve always stayed torqued up to what i put them at ......
« Reply #7 on: 04 March 2012, 19:53 »
Yep radius.
Yes most factory alloys use radius, aftermarket is taper (some aftermarket alloys do use std bolts but it is rare)
If they are genuine then your using the wrong bolts.
Offline rockmonkey69
« Reply #8 on: 04 March 2012, 21:12 »
Agree with Wayne, it might well stay torqued up but it is not right or safe. The contact between wheel bolts and the wheel is lessened - not ideal! More clamping force is applied to a much smaller area. For the sake of a tenner or so it's worth getting the correct bolts for the application.
