Author Topic: OEM Quad Headlight Grill info  (Read 14432 times)
Offline Jamtarts
« on: 04 March 2012, 16:37 »
Hi,
I managed to pick up an OEM Quad Headlight grill, for my Mk 8v gti, to replace the debagded grill that was on the car when I bought it.  I eventually got round to fitting it today, however the second set of lights don't work, as far as I can see I've plugged the cables in properly.
I am not sure about the grill at all, and I wondered if anyone had any info on it, just in case I'm doing anything silly?  Is there a switch for them I should press, maybe it could be the fuse or the bulbs are damaged due to the postal transit?
I'm hoping it's something really simple and it's easy to sort, has anyone any ideas I could check before taking it to auto electrician?
thanks in advance :)
Offline SoundillusioN
Re: OEM Quad Headlight Grill info
« Reply #1 on: 04 March 2012, 17:08 »
Have you tried ignition on and then switching on full beam?
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 04 March 2012, 17:09 »
Use a multimeter to continuity test the light loom to the lights.
Pics help.
Offline mk2bal
« Reply #3 on: 04 March 2012, 17:27 »
Or check for 12v at the lights when you should have, ie when switched on full beam. If not, work your way back through wiring
« Reply #4 on: 04 March 2012, 18:01 »
 :grin:
Well about 9v standard at the most, unless he's upgraded his loom.
Offline mk2bal
« Reply #5 on: 04 March 2012, 18:03 »
Doesn't matter, if there's power there then the bulbs are gone
Offline Jamtarts
« Reply #6 on: 04 March 2012, 20:55 »
Thanks guys, I'll try and have a go at them tomorrow, I don't have a multimetre and I've never used one before but I'll see if I can get my mate on the case and check it, I'm hoping it's something silly and I don't have to take it off again :)
I did get a couple of pics on the mobile, i'll try and post them just now, but I'm not sure if they'll help,
Offline Jamtarts
« Reply #7 on: 04 March 2012, 20:58 »
passenger side connector for the inner lights (not working)...
Offline Jamtarts
« Reply #8 on: 04 March 2012, 21:00 »
driver's side connector for the inside lights (not working)...
Offline Jamtarts
« Reply #9 on: 04 March 2012, 21:01 »
the grill before fitting...
