Author Topic: Catch can fitted,pcv deleted, now limp mode.  (Read 1320 times)
Offline Big Tone
« on: 03 March 2012, 20:12 »
Re fitted catch can, deleted pcv system as per how to guide.
Now shes in limp, wont boost past 5psi.
Only code is 17705, no obvious leaks, holds 5psi smoothly, no fluctuation at all.
Will pressure test tomoz...... Feckin golf!
« Last Edit: 04 March 2012, 07:18 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline daz veedub
  • Operation 1.8t bolf
Re: Catch can fitted,pxv deleted, now link
« Reply #1 on: 03 March 2012, 20:25 »
bugger ive not drove mine since fitting catch can  :undecided:
gotta be a leak somewhere mate
Offline harlemex
« Reply #2 on: 03 March 2012, 20:48 »
just remember, the how to guide takes no responsibility  :grin: :evil: :evil:
Offline Big Tone
« Reply #3 on: 03 March 2012, 20:59 »
Aye, its just finding it that will be the tw+t
Offline cullygti
« Reply #4 on: 03 March 2012, 21:34 »
oh great was gonna do mine tomorrow if weather is good cant be doing problems s need car for work so may just leave it till i get some time off  :smiley:
Offline Big Tone
Re: Catch can fitted,pcv deleted, now limp mode.
« Reply #5 on: 04 March 2012, 07:19 »
Driven to work this morning....fine.    Wtf?
Maybe slightly low boost, but not much. Feckin golf!
Offline Big Tone
« Reply #6 on: 04 March 2012, 15:59 »
Found the fecker!!!!
Split pipe under inlet manifold, repaired and leak tested again.
Since deleting the pcv system the system is as air tight as a nuns cu+t!
Looking forward to ripping it up on the way home!
Offline rockmonkey69
« Reply #7 on: 04 March 2012, 16:05 »
Glad to got to the bottom of it, the Pcv delete leave little else to go wrong should you have a leak it makes looking for it a lot easier!
Offline Big Tone
« Reply #8 on: 04 March 2012, 16:42 »
Should????? You mean when! Lol :grin:
