Author Topic: Rough running!  (Read 781 times)
Offline Ashleydwsmith
Rough running!
« on: 02 March 2012, 22:22 »
Hi,  haven't been on here for a while.  Just had the starter motor changed, but now the car is running rough!  I.e at idle after acceleration it is up and down.  Imagine how it sounds when you first start it from cold and the auto choke kicks in! It revs up then down.  It doesn't rev high, it's more like it drops to below 800 and then pops up and then down again!
Don't have a fault code reader and kinda hoping it's summit simple,  hope you can help?
It's a T plate 1.8 T
'99 1.8T GTI, indigo blue. Agu.
Offline daz veedub
  • Operation 1.8t bolf
Re: Rough running!
« Reply #1 on: 02 March 2012, 22:24 »
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: Rough running!
« Reply #2 on: 02 March 2012, 22:38 »
tried throttle bodie clean
http://www.golfgtiforum.co.uk/index.php?topic=87783.0
+1 id try this first takes half hour and only costs a few quid for carb cleaner.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Re: Rough running!
« Reply #3 on: 03 March 2012, 07:29 »
Might give that a try before sending her to a garage!  Any other possibilities, was thinking it might be the MAF after looking at the mk4 fault topic.
Offline richw911
Re: Rough running!
« Reply #4 on: 03 March 2012, 18:17 »
Could be loads of things get a cheap code reader and save yourself some money  :wink:
