Author Topic: 16v conversion radiator  (Read 1359 times)
Offline Aubrey1982
« on: 24 May 2005, 23:30 »
Hi i will  soon be starting my 16v conversion into my 1.1c i have a 16v donor car, but a mate of mine has asked for the rad out of it, will it fit in the mk1 as i dont want to give him mine and then end up having to buy one myself.
cheers guys.
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
Re: 16v conversion radiator
« Reply #1 on: 28 May 2005, 01:19 »
There are 4 different radiator sizes that I know off.
430mm,525mm,630mm and 720mm. You can fit up to 630 on the MK1 easy. You might to use a smaller battery and relocate the power steering reservoir if you have any (probably not as you never got PAS in UK). The last two are utilising a dual fan setup with one motor and a belt to drive the second fan.
Other than that, any radiator will work just fine provided the system is clean and there are no leaks.
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
