Author Topic: Rust around windscreen  (Read 2895 times)
Offline Mart8V
  • I really should know better by now.....
« on: 24 May 2005, 22:35 »
How do I best attack this bloody stuff?  Seems to be half under the rubber seal, and also around the "spare" wiper mount.  The latter I can do, but do I need to get the screen out to really get at the rest? :huh:
Offline ...joe
Re: Rust around windscreen
« Reply #1 on: 24 May 2005, 22:46 »
to do a job worth doing, yeah you really need that screen out. carefull though as its a common place for mk 2's to rot and there may be alot more lurking there than you think! it may mean a trip to the body shop to get some welding done! :sad:
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Splinter
« Reply #2 on: 24 May 2005, 23:27 »
You need to spend £20 - £30 get the right tools for removing screen, like these http://www.drapertools.com/draper/templates/draper/details.asp?newrecordset=yes&classlevel=39
It can be an easy job, or it can be a right pain, 50/50 depends if its really bonded in well after a replacement screen. Rust probably caused from an incabable autowindscreen guy anyway.I've never seen my mate struggle (to much) with windscreens when spraying. Puting them back in is easy.
A bodyshop will be more than capable of removing it though. A few years ago my Mondeo ST200 had a replacement screen fitted by Auto windscreens at work for stone chip, I kid you not it took him 7 hours to remove & re-fit, I had glass everywhere (down back of dash, etc) and scratches on the bonnet because he never covered it. I very nearly smacked him and so did one or two lads at work, cos they liked that car.
" Do it today, Don't wait until tomorrow "
Offline Mart8V
« Reply #3 on: 25 May 2005, 08:02 »
Bugger.  Might be a case of some careful work to remove surface stuff for the time being and then have a proper go at a later date.  Not that confident about removing the screen- might head off to local scrappy and practice!
Offline Mart8V
« Reply #4 on: 31 May 2005, 20:11 »
Have had a look around inside and behind dash and seems to be sound- nothing that a screwdriver would go through, or even bend.  Looks as though it may be surface only at this stage.  Fingers crossed......
Offline The Hoax
« Reply #5 on: 31 May 2005, 22:18 »
Prise the screen rubber back a bit at a time with a plastic tool and pour some warmed waxoyl in allowing it to seep in. That should keep things at bay.
« Last Edit: 31 May 2005, 22:20 by The Hoax »
Offline *Dubby*
« Reply #6 on: 31 May 2005, 22:20 »
theres a bit in the latest VW Motoring mag about replacing a screen  :wink:
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline Mart8V
« Reply #7 on: 01 June 2005, 09:32 »
Cheers, Dubby.  Off to Smiths...... :smiley:
Offline filthy
« Reply #8 on: 05 July 2005, 21:40 »
My screen surround is so f**cked that i've got water pissing in on both sides of the car- anyone make replacement panels, or is it a trip to the scrapyard to chop out a scuttle?
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
