Author Topic: silcone pipes  (Read 970 times)
Offline navmk4gti
silcone pipes
« on: 01 March 2012, 21:00 »
quick q guys... are the boost hoses on the AGU and AUM the same??
and is the tip (induction pipe) the same on a AGU and AUM??
thanks  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: silcone pipes
« Reply #1 on: 01 March 2012, 21:12 »
The only difference I've found is with the AUQ, the elbow has a slightly different design due to the silencer.
AGU and AUM TIP are totally different, you'd need to block off a hole on the AUM TIP and also swap the hockey puck and DV around to use it on your AGU
Offline navmk4gti
Re: silcone pipes
« Reply #2 on: 01 March 2012, 21:29 »
wikid.. so the boost pipes same on agu and aum.. and tips are different.. :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: silcone pipes
« Reply #3 on: 01 March 2012, 22:40 »
you got it :afro:
