Author Topic: Not starting, faulty throttle housing  (Read 1194 times)
Offline sparky2010
« on: 01 March 2012, 19:10 »
Hi, had gone out the other night, car was fine on the way out and come to start the car to go home and did not start for love or money. When I turn ignition on I hear a clicking nosie from the dashboard continuously, I looked under the bonnet and noticed that the throttle is partly opening and closing continuously.
I have tried to read the fault codes but when I try my reader just comes up with error!
I have tried disconnecting the throttle housing lead and turned on the ignition but the clicking from the dashboard continues to click away.
I aussme that there s a major fault with the ecu!
Please help!
Offline kennedyuk2001
Re: Not starting, faulty throttle housing
« Reply #1 on: 01 March 2012, 19:22 »
Try disconnecting the battery for half hr.
Offline richw911
« Reply #2 on: 01 March 2012, 19:38 »
Check the fuses for the ECU no 10 / 43 http://www.golfgtiforum.co.uk/index.php?topic=87372.0
Offline sparky2010
« Reply #3 on: 03 March 2012, 21:48 »
Right have checked the fuses and all ok, have tried disconnecting the battery, have also removed the throttle housing and cleaned it but still no joy. Has anyone got any more suggestions?
Offline richw911
« Reply #4 on: 04 March 2012, 00:44 »
Checked the fuses on top of the battery? Earth leads ok? Battery terminals ok/ Battery fully charged?
Offline sparky2010
« Reply #5 on: 22 March 2012, 20:51 »
Right have doubled checked all fuses and have changed the petrol pump relay but still no joy. When I pull the fuse out for the ecu all the clicking stops and when a pull the cable connector out of th thottle housing it all seems ok. So I assume that the throtte housing may be faulty.
Offline rio_gti
« Reply #6 on: 23 March 2012, 16:54 »
get another tb and plug it in
where abouts are you?
Offline sparky2010
« Reply #7 on: 25 March 2012, 10:46 »
Thanks rio_gti, I'm in Guildford in Surrey. Will look for one on eBay. Cheers
Offline rio_gti
« Reply #8 on: 25 March 2012, 11:06 »
It is drive by wire isn't it..... I got one in my garage u can try befor u go spending money on one just incase ts not that
Offline brianpologti
« Reply #9 on: 26 March 2012, 17:30 »
Have you check the battery ? Try simple first ,
