Author Topic: MK3 golf GTI not starting help needed!  (Read 1713 times)
Offline MattMK
« on: 01 March 2012, 13:51 »
Hi all I'm really in need of some help! I have done every thing I can think of! I have changed: coil, dizzy cap, rotor arm, leads, plugs, ecu temp sensor, crank sensor, the usual relays its had a new battery and its still won't start! I'm getting a fairly weak spark and some odd voltages at the main engine plug like 3volts etc, when turning over it stinks of fuel!
Any help would be so helpful!
Matt
Offline AlexMozza
Re: MK3 golf GTI not starting help needed!
« Reply #1 on: 03 March 2012, 00:06 »
Tried VAG com?
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2 on: 03 March 2012, 00:11 »
timings out i recon try changing your plug leads around if they were new did they go back on same way they came off? Also check the coil pack again and make sure all earths are back in place next step is rotate the dizzy 180 degrees  :smiley:
Offline MattMK
« Reply #3 on: 03 March 2012, 09:25 »
Tried VAG com?
Yeah mate it doesnt bring any faults up
Im sure the leads are on the right way mate i changed them one at a time  :smiley: as for the timing could you explain it to me lol i read about it breifly but didnt really get it
Thanks for the replys
Offline AlexMozza
« Reply #4 on: 03 March 2012, 21:48 »
There should be a retaining nut on the stalk of the dizzy, loosen it and rotate the whole dizzy around though 180
2001 Satria GTi
Formula 3 Mechanic
